Don't worry Pat, possibility of me moving there at the end of the year...so you'd have me give free chocolate to :)
Same job Pat? More money? Exciting times
haha unfortunately not same job/company. Am changing company and industry. Exciting time indeed.
How'd you get that job Pat? Apply or head hunted?
this one i applied for but turned down head hunted offers during the process
cotdayum, Pat on dat dere 6 figure baller spec I'm guessing :P
how can one put a price on friends and family?
yh, my friend is doing fifo. dat 40% increase of salary.
Dont think hes gonna do it for long. Hard for him being away so much.
FYP brah dat 150kw engine
anyone been to bali? few mates want to go for new years but i'm still undecided if i can be bothered spending ~3k all up for just bali
I'd put that money towards a holiday which has more to offer than drunk bogan aussies.
Tony would have some good recommendations from his honeymoon. I'd rate Vietnam.
I loath Vietnam
had such a bad run there.
try somehting new
Boracay in the Philippine's is interesting.
Fiji always better than bali
or if you jsut looking to get drunk/stoned and chase chicks try:
http://en.wikipedia.org/wiki/Vang_Vieng
I loath Vietnam
try somehting new
I enjoyed Vietnam, but I guess that's how travelling overseas is. People can have the best or worst times at places
I would definitely go back, especially with the group I was with, made it heaps more fun
pat goes to wa
10 yrs later
pat comes back to vic
pat is now pimp
pimp owns gold plated r32
pimp also buys final inspection
10 years later
Mohsen still trying to fix his r32 and is still gay
10 years later
And still dates 13 year olds
Ive always wanted to check out the Maldives or even the north beaches of Sri Lanka. apparently its tops. Maldives is supposed to be super $$$ though... not that ive looked into it or anything.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
