ASUS G75VX
CPU: Intel 3rd Gen. i7 3630QM 2.4GHz (Turbo 3.4GHz)
OS: Windows 8 64bit
RAM: 32GB DDR3
HDD: 256GB SSD + 1TB SATA
Graphic:Nvidia GTX 670MX
3GB GDDR5 VRAM Dedicated VGA
Screen: 17.3FHD LED Screen(1920x1080)
UBB3.0 * HD Webcam* WiFi N * Blu-Ray Writer * DisplayPort * HDMI * Bluetooth
Awww yeah
I've just read up that the 4th gen intros came out. With dell Alienware being one of the first laptops to offer it.
Also new nvidia graphics card but that puts it to a price of $2500 :x
Might get the 4th gen intel and compromise on the gfx.
And no idea why ppl think I travel much!!!!!
I've never stepped outside of Australia! Stop complaining you!
Stagea brakes the same, better or worse then the GTT?
The latter..
Stagea brakes are more like na skyline/s13 brakes, single sided twin piston fronts, single piston rears
^ This man knows. :unsure:
Haswell worth it for the battery life for sure, man.
am thinking this one;
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389935#!tab=specs
Intel® Core™ i7-4700MQ (2.4 GHz, 6 MB L3 cache)
NVIDIA GeForce GT 740M (2 GB DDR3 dedicated)
15.6" diagonal Full HD BrightView LED-backlit TouchSmart (1920 x 1080)
Weighs 2.5kg but has haswell, 740M & touch screen for $1000~
or the 17" non touch screen
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389947#!tab=specs
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
