Tread pattern is the same.
It's a different compound. Increased grip at temperature.
They might have had a play around with the sidewall as well, not sure.
But they are still selling both AD08 and AD08R. The R is only available in certain sizes at the moment.
$420 / tyre!!! No way.
OTR if you want AD08's or RTR if you want RS3. Both are under $400 / tyre.
iirc the AD08 is around $385 and the RS3 around $370.
You should, might, kinda be able to get AD08R's in 265 from OTR as well.
Hokie dokie! I'll keep that in mind
Tirerack would be good if the dollar was better
listed at $263USD a tyre on tirerack. But once you add shipping, GST, duties and convert back to AUD it gets exy
Oh, I see.
Edit: what's the tread wear rating on these two?
Well there is a story there....
AD08's are 180.
RS3's are 140 & 200. However there is no difference between the two. They simply had the tyres re-certified at a higher utqg for a racing series they were competing in. The 285/35 R18 RS3's I've used were 200 utqg.
Noticed any difference in wear between these two?
I know you run both in different size so that'd be in-direct comparison but I'm curious and I'm sure others will be too.
How many trackdays did you do with a set of ad08s before moving on with rs3's?
I only ran RS3 as I couldn't get AD08 in 285 or 295. I've done 15 track days on AD08's previously. Those tyres have gone on to be used another 5-6 times.
Ombudsment has taken on my case on the basis that my termination fee is more than my remaining balance.
Telco will be in touch to discuss
told ya... tell them you want to keep the handset and terminate the contract. Moving for work was unavoidable and you purchased the product in good faith assuming that there would be coverage in all major areas etc.
if you sound like you wont accept anything less, however don't come across as arrogant they will likely just give it to you as a commercial decision
f**ked it up. Rookie mistake.
Agreed to pay out the outstanding months ($290) vs the original termination fee of $440
Should have argued to get it less as there is no difference in keeping or cancelling the contract.
Ah well, next case ill be aware.
dw, fifo ymcmb
you can afford it
bahahaha
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
