Yeh really good. Recommend the carnival cruises for when you CBf organizing accommodation, food, entertainment.
Everything was actually really good!
would love to go on a cruise, but with the inlaws living in port douglas/cairns the wife wants to go there 3 times a year. i dont mind it but it gets boring.
who was the company you went with bro? what was the age group like?
"Any foreign currency transaction charged to your
account where the merchant or financial
institution accepting the card is located outside
of Australia. 3% of value"
Now... would you guys expect to get slugged this fee when your card is refunded to (not charged) ?
Carnival spirit.
Went to noumea(new caledonia), marè, port Vila and Vanuatu.
Age group varies a lot, school holiday as well, but majority was 20-35.. Out of the 2000+ guest
I actually barely got bored. Heaps of plays which I wasn't expecting to be so good, service is great, meet heaps of people.. Almost as if 10 days isn't enough, but when is any amount of holidays enough..
So Warner Brothers is making a sequel to Bladerunner
and for some reason they chose NOT to go with Ridley Scot, and to chose this Transformers-directing, CGI-worshipping, plot-ruining dickbag,
He has decided that the movie will have heaps more special effects, and will "stand up" to current CGI fests like avatar, etc.
BUT
He has also stated that in Scott's original, the viewer had trouble working out which characters were robots (replicants) and in his version the viewer "will definately be aware which characters are robots"
THAT WAS THE WHOLE POINT OF THE FILM YOU f**kING MORON!
IT IS A MOVIE WHERE THE MAIN CHARACTER'S JOB IS TO WORK OUT IF PEOPLE ARE REPLICANTS OR NOT BECAUSE IT'S IMPOSSIBLE TO TELL
ALSO, THE CRUX OF THE WHOLE FILM IS DECKARD WORKING OUT THAT HE IS IN-FACT A ROBOT BUT NEVER KNEW.
FFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUU
  • Like 1
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
