I still cant get over A45 250kw from a factory 2L.
the day draws nearer when the pulsar can have its arse-handed to it by production hatches and will be the slow 70's hatch equivalent of today
my falcadore will smash a c63 brah! do want though!
nah but srs they are mint, too bad the coupes are more expensive cos they look heaps better than the sedans IMO!
some guy down the street has one, sounds mint as fuark.
loled @ that vid
Apparently that new HSV GTS did a 12.6 with '430kw' in a magazine review
Edited by UNR33L
Not too bad man. Yourself?
Good thanks.
Grandma passed away last night so I think hes going to bury her and then sort out his dads visa stuff and then come back.
That said he's doing everything in lebanon so he wont need to stay in syria
Sorry to hear about your Grandma.
The situation in Syria is terrible in general.
c63 a nice family car in a few years I spose lol
Until your kids are about 3-4 years old lol. They aren't a roomy car.
My business partner has one- best sounding car you can get, great looks, classy and neat interior.
But good luck getting traction. The transmission isn't quick/smooth either, although I think they rectified this in newer models (wet clutch or something like that). Oh and no LSD standard- unless you have the performance pack version.
Time to go for 250-300fwkw in the Pulsar Leroy
That should keep you ahead of production cars for another few years :P
lol car would be limited to dyno queen duties and Show'n'shines. gearbox would be on edge.
...i'd probs go E85 if I wanted more...
inb4 Scotty propaganda
loled @ that vid
You mean your modified falcodore can beat a stock c63. Well done
Good thanks.
The sedans are quite roomy, not to mention the wagons
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
