I still cant get over A45 250kw from a factory 2L.
the day draws nearer when the pulsar can have its arse-handed to it by production hatches and will be the slow 70's hatch equivalent of today
my falcadore will smash a c63 brah! do want though!
nah but srs they are mint, too bad the coupes are more expensive cos they look heaps better than the sedans IMO!
some guy down the street has one, sounds mint as fuark.
loled @ that vid
Apparently that new HSV GTS did a 12.6 with '430kw' in a magazine review
Edited by UNR33L
Not too bad man. Yourself?
Good thanks.
Grandma passed away last night so I think hes going to bury her and then sort out his dads visa stuff and then come back.
That said he's doing everything in lebanon so he wont need to stay in syria
Sorry to hear about your Grandma.
The situation in Syria is terrible in general.
c63 a nice family car in a few years I spose lol
Until your kids are about 3-4 years old lol. They aren't a roomy car.
My business partner has one- best sounding car you can get, great looks, classy and neat interior.
But good luck getting traction. The transmission isn't quick/smooth either, although I think they rectified this in newer models (wet clutch or something like that). Oh and no LSD standard- unless you have the performance pack version.
Time to go for 250-300fwkw in the Pulsar Leroy
That should keep you ahead of production cars for another few years :P
lol car would be limited to dyno queen duties and Show'n'shines. gearbox would be on edge.
...i'd probs go E85 if I wanted more...
inb4 Scotty propaganda
loled @ that vid
You mean your modified falcodore can beat a stock c63. Well done
Good thanks.
The sedans are quite roomy, not to mention the wagons
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
