God I hated customers like you when I was doing gearboxes. Always want somethig that can be everything. Oh I have 9001rwkw but it's my daily driver so I want a soft/friendly clutch but I like to give it a thrash so I need to be able to launch it hard oh and I don't wanna pay more than about $400 for it.
Fast/friendly/cheap, pick two...
Closest youll come to all three for that power level is an NPC Carbotic 10" for around $500. It is an organic clutch rated to 300rwkw and a bit firmer than standard clutch.
Where is your F40 Pat
Haha the mining life is not like as perceived in the east coast.
Trying to save for deposit + pay rent in Perth + pay mortgage in Melb.
Worse off day-to-day living than before ~_~
Final inspection/micolour may have to wait now haha
Or I could disregard financial planning and acquire f40 haha
guys. clutch talk.
car will have around 300rwkw and will mostly be a week end car, sometimes drive it to work since its close etc.
I what is a decent clutch that wont break the bank? id love a nismo twin plate but yeah nah lol
would want it to be nice to drive and be able to take a beating when I track it..
its boiling down to buying the little things to finish it now :)
I like xtreme. dont know about for skylines though.
http://www.xtremeclutch.com.au/en/catalogue/xtreme-clutch
guys. clutch talk.
Just cough up $ for Coppermix twin.
Or find OS twin/triple.
guys. clutch talk.
os twin plate mang, you will never regret it.
or you'll regret it just a little, then you'll learn to be a man.
guys. clutch talk.
This one
http://www.ebay.com.au/itm/RedBull-Racing-2007-RB3-Main-Clutch-Housing-Coulthard-Webber-F1-Part-Formula-1-/281141040011?pt=UK_Sports_Memorabilia_ET&hash=item41754fd38b&_uhb=1
Sunkist, on 30 Aug 2013 - 07:43, said:snapback.png
2009-2010 depending on condition go from 70k to 90k..
2011-2012 go from $110 - $130k.
You want? There's a prestige auction coming up in belmore soon. There's a nice handful of them in there
Might message you again next year sometime... Also thinking Audi S5 etc
Nah it's for maximizing resale for me brah. Not worried about break downs
S5 is easy in the 70k range Dezz my mate almost bought one 6 weeks ago for $74k out 30kms on it
Would be a weapon mines only the 3.2 6 and it goes fair well so the 8 would be awesome
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
