Nah it's for maximizing resale for me brah. Not worried about break downs
S5 is easy in the 70k range Dezz my mate almost bought one 6 weeks ago for $74k out 30kms on it
Would be a weapon mines only the 3.2 6 and it goes fair well so the 8 would be awesome
only 70? What year?
RS5 would be sick
Lol it's not that bad man, even my coupe has a fair bit of leg room in the back..
It's not bad at all, I guess I wouldn't think it ideal for a family though.
Also I'm a bit confused, I think you've mentioned you work for Mercedes in the past, but now it seems you work for an auction house? Please clarify lol.
I work for Mercedes Benz, but I and another girl handle all the repossessions for mb finance.. Aswell as other things
Awesome!
So with the repos- are they auctioned via Manheim/Pickles etc? Or is there something I don't know about lol.
Just a quick enquiry- any G55 AMGs?
Awesome!
Yep Mannheim and pickles, Mannheim usually get out fleet stuff..
There is one G55 in belmore lol goes up on Tuesday! Should be on the pickles site now
Awesome!
Boss car although the new GL AMG is way hotter I rkn the G is a bit strange on our roads and resale would be disaster since nobody has em I rkn
Edited by alr33x
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
