1) Can I book a test drive? 2) I have enquiry regarding price. 3) Can I please have more information on service history? 4) Hi, Just viewed your listing and will like to purchase it. can you advice on how long you have had the vehicle, why you are selling it, has it ever been damaged, what condition is it in, will it meet a RWC, does it have any bad habits and your final price? I will be Glad if you can send me some pictures.. Kindly get back to me as soon as possible. Awaits your response Steven
Can I please have more information on service history? Please kindly advice on the final price and the present condition...
Interested in your listing,can you send more pictures(insideespecially) to martianlabelle(at)gmail(dot)com.Regards
^ Enquiries about a car I have for sale on drive.com.au, are these scam replies or legit do you think? If scam, what blipped on your scam radars?
Car is a 2006 Alfa Romea GT Selespeed
legit.
no mention of kenya.
Well it's not my Alfa :P It's listed at 16,000 atm... would explain why it's had no bites for 3 months...
Then suddenly 3 in 2 days... from separate people...
The first one looks the most suspicious... I mean, why would his point #4 start with "4) Hi, ", sounds like a copy pasta
The broken english concerns me, though after seeing posts on drift sales, not much phases me anymore.
Sif not swap for a 33
Soooo... trying to sell daily bcoz company vehicle, but swap for unknown condition R33 so I can sell the parts for more than what Evo 8 parts go for?
profit?
dat SAU logic
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
