Adding to the VicRoads rip off saga...
Just replaced spark plugs in car...it runs 63 times better...10,000km is too long for copper plugs in a modified car methinks. Though that interval was more out of procrastination.
The only reason I let mine stretch to 10,000km sometimes is because of the bloody RB crossover pipe and not wanting to scratch up my pretty valley cover paint if I don't remove it (+20 minutes) to the job.
I remember my old ford laser... Pop off the leads, unscrew plugs, screw new plugs in, cry because you drive a ford... Finished in 5 minutes
That awkward moment when your housemate receives a letter in the mail from the Australian Federal Police.
those guys hardly deal with misdemeanors or misunderstandings. I wonder if it also deals with Immigration issues, or would the Department Of Immigration just deal with it? maybe terrorism or illegal visa. hmmmmmmm *curious*
This
It's a 30 minute job that should be 10 minutes.
And working with old hoses and screws, I'm ultra careful about the way everything goes back.
I leave the valley cover off, so I can do 5 of 6 plugs without touching the pipe. But Nissan Y U put crossover pipe slightly too far over the 4th cylinder? If I had uni-joint sockets I could do it, but don't really like using those unless I have to.
Can't get started, Chemical Heart... Every time I get started, you pull me apart.
Old Grinspoon is the best Grinspoon
dead Grinspoon is the best Grinspoon
I ran BCPR7ES gapped to .9 and used to change every 20,000, even when changed they worked fine and looked 100%
dat trent tune
