Because Mohsen...
It heard you wanted a VL so it decided "Meh, I'll just single for a while... same same..."
Hey hey. A spool a glide and a 42... all a vl needs. Run 9s and pop wheelies errrrrday
yeah we all know they're a bunch of wankers one day they're going to go too far with the wrong person and someones going to get shot or killed over modded car related issues.. my brother is PISSED atm
I kinda want something bad to happen to a stupid hwy patrol cop, they might re-think some of the stupid fines/defects then? I duno.
that is how they SHOULD handle it, but yo KNOW they would just crack down 11ty times harder. would just be all out war on import cars
VL's are shit cars and uglier than a hatfull of assholes. they are only driven by complete wankers with no prospects of a decent life beyond 35 when they finally leave their parents house to explore their closet homosexual tendencies with their cousins while listening to some 2005 ministry of sound shit, and I SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO want one!
FYP
  • Like 1
also have been yelled at by coppers for not pulling up instantly to avoid a restricted zone lol
Apparently there is no requirement to pull over if they are behind you with lights on. If they pull up beside you and gesture, or pull in front with their indicator on and force you to stop you must.
My mate tried this out, lulz were had. Female cop wasn't happy when he finally pulled over...
I feel a SAU Vic Reefton Spurs cruise coming? :D I went there couple of weeks ago with some RX-8 mates, no cops the whole way (5 hours all together). T'was pure fun just us, evo's and lots and lots of motorbikes.
Photo:
1239005_10151747340972762_48628241_n_zps
Photo:
Hmm no cops you say...
Ahhhh I was thinking it was KnoxPol again...
Country cops + Imports... "We don't like ur kind round 'ere..... hey boy... hey boy.... you lookin mighty cute in dem jeans..."
KnoxPol actually act on the urges... and ream you in the exhaust
lolol there usually are cops but just depends on when you go i guess brahs, the speed limit on and around those mountains vary from are 70-110 and 50 in the towns but not complaining about the mountain limits!
Edited by r34abz
Country cops are shit if you're not local. Last I got done for doing a U turn over double lines (at 1am with no cars in sight), the prick made a point of saying "now I know you're used to the city, but down here we have a lot of accidents from stuff like this." "You'll get a fine in the mail cause I'm a fat lazy flamin mongrel who can't even tell you what the penalty is on the spot." Scumbag
I always have good experiences from country cops...
often pulled over however always able to smooth my way out of it. just admit to what you did and let them know how much of a better experience it is being pulled over by a country cop and how bad the city cops are.. .works a treat (unless you get a city cop that's in the country for some reason THEN you are f**kED)
I have said it before and i'll say it again... respect and attitude goes a LOOOOOONG way with cops
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
