I'm guessing that's a GTA reference?
It's been over a decade and a half now since the release of goldeneye 64 but I STILL feel the urge to shoot surveillance cameras
And I still feel the urge to squish guys in my tank on my airport runway; life and nostalgia is funny like that.
range rover overfinch.
maaaad.
600hp.
will destroy anything. on mud or road.
Bowler nemisis would like to disagree
Angus is peppered
Booked for 2 @ 6p.m Saturday night at Clayton Lawn bowls
Lets have a taste of this Vue Du Monde food!
sweet... post results in restaurant thread :)
I'm not booked for a few weeks
inb4 Clayton Bowls Club sell a heap of parmigianas to you lot cause the guy has already left / it was all a joke on hipsters.
would be epic joke... would still buy parma....... because parma
If you want a parma, come to the SAU Vic monthly meeting this month ;)
Going to smash dat shiz so hard it'll start crying and pretend it didn't want it all along
typical parma broad minded person.
Was it geology with melbourne uni by any chance? I did a week in torquay there in 09, it was exactly as you described it
Yeah that sounds like it haha doing it as my breadth this sem, t'was really good. :)
Yeah I don't do Frankston or Dandenong after dark, I've seen the dodgy people there during the day... not worth the risk...
What?!
I've lived in Frankston for 13 years, and I can assure you there's worse place to be in... *coughs* sunshine...
Is the implication there that my anus is so loose I wouldn't realise if I had been raped?
Angus is peppered
Lets have a taste
Edit: These quotations may or may not have been taken out of context more than the Range Rover vs Bikers story
inb4 1/2 of Wastelands bump uglies Saturday night
i should come to more meets
I lived in dandenong for 5 years. It was probably me that you thought was dodgy
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
