$5.5k for both eyes?
What kind of eye defect?
I'm short sighted... a lot... -7.25 and -7.5... wonder if its the same price :/
yeh both eyes, i was short sighted i think about -6.5 or similar. Should be the same price - this is if you are a good candidate (ie thick enough eye to cut a flap in)
Edited by UNR33L
ASLA is an alternative if not.
Is it true what they say about it only lasting for 10 years? and then you can't get it done again in the future?
Or is the tech advancing, so in 10 years time even if it does fade and I start needing glasses again, something else will be there to fix it again...
That's wrong, my dad got it done almost 20 years ago and still going fine.
The Dr said probably 50s or 60s i might need reading glasses but thats about it. So normal really. Its great for all the little things in life that glasses piss you off with.. showering..sunnies..beach..amusement park rides..helmets etc
^lol eep!
/glasses4lyf
well, for now at least. don't even wear contacts!
and nothing like coming home from work to find out there is an assignment due tomorrow - and not next week as everyone had thought. fffffffffuuuuuuu.
Only has -1.5 and only one to wear glasses O_o
You all blind Kents :P
Which month going Singapore birds?
I can fly return Singapore for $300
/dat Perth living
In two weeks lol
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
