You shittin me? They cut your eye while your watching? Or can't see cos mostly blind prior to incision?
Yep they hold it open with clamp things cut flap, fold flap over laser and reshape eye, put flap back on. You loose vision for a little but all good.
Edited by UNR33L
sooo.. new season,
strike the blood
outbreak company both brought some lolz.
Have some episode ones downloaded, just haven't had time to watch yet!
Recently watched danganronpa which I didn't think was too bad, but apparently the game is heaps better. Reminded me of 999 game, which was pretty fun.
I heard that you can smell getting your eye burnt whilst doing laser eye surgery. Haha
yeah smells bad, they tell you it's the machine and not to worry about the smell but i'm a bit sceptical
Did you get Lasik or PRK laser eye surgery?
I heard PRK is better but has alot longer recovery times
Lasik you pretty much have the vision straight away
ASLA is a refinement of PRK
1 week vs 1 day for Lasik :-/
http://www.sydneyvision.com.au/index.php/alternatives/
Yeah i've heard mixed reports. Some people are fine after a week. Some have taken up to 3 months to heal and reach 20/20
My brain has exploded reading so many pages since yesterday from this forum. Its quite informative
http://forums.whirlpool.net.au/forum-replies.cfm?t=1258336&p=79
Lasik, I think my cousin had the other one with the implants or whatever but took a little longer to recover it depends what your eye is like.
Mine were nice and thick plenty of space to play with and do the good way.
Edited by UNR33L
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
