You shittin me? They cut your eye while your watching? Or can't see cos mostly blind prior to incision?
Yep they hold it open with clamp things cut flap, fold flap over laser and reshape eye, put flap back on. You loose vision for a little but all good.
Edited by UNR33L
sooo.. new season,
strike the blood
outbreak company both brought some lolz.
Have some episode ones downloaded, just haven't had time to watch yet!
Recently watched danganronpa which I didn't think was too bad, but apparently the game is heaps better. Reminded me of 999 game, which was pretty fun.
I heard that you can smell getting your eye burnt whilst doing laser eye surgery. Haha
yeah smells bad, they tell you it's the machine and not to worry about the smell but i'm a bit sceptical
Did you get Lasik or PRK laser eye surgery?
I heard PRK is better but has alot longer recovery times
Lasik you pretty much have the vision straight away
ASLA is a refinement of PRK
1 week vs 1 day for Lasik :-/
http://www.sydneyvision.com.au/index.php/alternatives/
Yeah i've heard mixed reports. Some people are fine after a week. Some have taken up to 3 months to heal and reach 20/20
My brain has exploded reading so many pages since yesterday from this forum. Its quite informative
http://forums.whirlpool.net.au/forum-replies.cfm?t=1258336&p=79
Lasik, I think my cousin had the other one with the implants or whatever but took a little longer to recover it depends what your eye is like.
Mine were nice and thick plenty of space to play with and do the good way.
Edited by UNR33L
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
