Going up the Hume last night around 12am in mum's Passat, sitting on 110, and all of a sudden, bam, roadkill wombat sitting pretty in the middle of my lane. Huge m0therf**ker, car got just about airborne. Pulled over and assessed the damage: the fat c*nt ripped a chassis brace straight from its mounts, leaving a trail of blood, guts and fur for me to wrestle with unbolting it. Not a drive I'd do again unless in 4WD with a bar.
Edited by colourclassic
Drive up and down the Hume all the time, never hit anything.
Are you positively annoyed friend?
Also have no idea wtf this no fuel ting is about. Aint had any problems at all filling up.
Haha yeah it's like hitting a tree stump. They like 40kg
bad: psych assignment due tomorrow; have not started.
good: found it's only worth 20%, not 30% as i had previously thought.
this is getting the way of my pokemon playing, grrr :@
Psych assignments always look like they could be done in a single night, nek nyt...you've only just got all your references and not a single word on paper :/
Just finished a flamin mongrel of a psych critical analysis with/for Leesh. Took me back to university days :)
Hoping she I passed.
this is very true. and what's sad is, if i actually put in some real effort, started early... it wouldn't even be difficult. just a bit of time needed to organise all the references and thoughts into place.
as it stands... shallow-references and half-thoughts will be put into place... just gonna shamble something together! using my ultimate wing-research-writing technique...
y u no do mine while you're at it adam... :P
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
