Tyres do harden in the weather and tyres on cars are through heat cycles that help to keep them from hardening. The latter part may be total shit, but it made sense when I made it up.
Regardless, distributors note year of manufacture and sell older stock for cheap for a reason.
Yeah was thinking that too but got to consider tyres aren't made yesterday. Would be coming via boat from china which is months and by the time you buy them, they have been sitting for ages anyways.
Could argue a tyre going through heat cycles would cause more wear as it's expanding and contracting.
hmmm.... it's just that I've got an old set of tyres in the backyard out in the open, used to be in the shed but needed that space.
So two sets of wheels with tyres on both sets, and I want to swap them around.
Would they charge the usual or double because they're taking off and putting on twice?
I've got a pair of jack stands if you want to borrow.
Haha saw that today. Classic
Slow and annoying.
Bought a 34 GTT, saving up for another gtr or o/s trip.
You really need to just buy a car and stick to it
Hmmmm, what are AD08's worth in 265/35/18? Any good place to get them from, fitted, in South East or Bayside or even Dandenongish area?
Cheapest AD08's would be about 380-400 fitted
The newer AD08R's are $450-$500 fitted
O/S
play with cars later
I've done both before, think I might do both, can always sell the 34.
The o/s will be short burst not 3+ months like last time.
It's wishful thinking really, blame it on my attention span and genes (father switched cars a lot, grandfather does every year before retiring).
I mean to actually swap the tyres from set 1, put them on set 2, and the tyres on set 2 to put on set 1.
Just jack up the car at each corner and swap each wheel one at a time. Will take 10 minutes tops...better than a car place doing it. Have a wheel brace if you need it.
I think young Jonoe meant taking tyres out from wheels set 1 to wheels set 2 and vice versa.
Costs me $5 a corner to have tyres swapped, $10 if I want them to get rid of the old tyres, seeing as you're keeping both sets though that's not gonna matter.
The benefits of living out in sticks, low overheads.
keep putting off doing research/pricing into semi's.... will wait for my RSRs to disintegrate. Probably wont go RE002s again either cause they pricey for what you get, but then again I dont really do enough kms for wear and tear to be a problem (other than -3.5 camber wear)
cool 7 degrees and wet on Mt Dandenong. yay
this dude snuck up on me earlier. abdomen was bigger than my thumb
Abz where are you?
11degrees in melb ATM but being in the office and judging by the current status of my nipples, it's roughly 23.5 degrees.
hahaha lol'ed.
meant body temp with this constant fever. :/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
