Sounds fun...
I'm putting tyres on mine on Saturday
actually came in before after doing one already, I'll have them all finished in a couple hours
Then going to redo them with silver paint instead of clearing the bare metal and having the same problem later on, masking them will be ever more fun
Trying to turn motor on the stand. spins around and something jams it against the stand.. that thing was my wrist.. fully dressed motor too.. wrist is all kinds of f**ked. Xray tomorrow. Who wants to give me a rub and tug?
  • Like 1
Alarm key fob always keeps running out of battery, urgh. Will need to invest in some rechargeable or a stash of batteries now zzz
this plus every other electrical problem in my car.
re-connect battery after it goes dead in 2 weeks, alarm arms itself and you cant open any doors so gotta walk around the car for 15-20mins pressing the button to try and disable it. wish I could get removed, but brings down the premium :(
2 weeks... what else is there that's drawing power? you could test the current draw of the alarm / car with everything turned off
Since the battery has been dead before, it might have lessened capacity now... do you have a proper 3+ Stage Mains Plug-In Charger? Alternatively, you could buy one of those little solar panels which tickle charges when the car isn't running to keep it topped up :) Worked great for my dads old boat when we didn't go near it for a few months at a time.
Lol I've never come across an alarm that's ment to be good that has actually worked like it should!
I've had my siren literally explode battery's out of their holder twice which has caused it to be un-responsive to the key fob and the valet button inside.. I've had to cut the alarm out with a box cutter in the middle of the city to make it stop going off, I had it go off parked in my garage and it was unarmed which required I cut it out again to stop it.
Remote start neutral switch breaks every few months.. I could go on and on!
No wonder 'top of the range' viper alarms have lifetime warrantees, they break all the time.
You'll have to tell me what brand alarm to steer clear of when I get my next car!
Other week I'd discover that my 34 have a alarm and central locking when the guy I bought it off told me it's just a immobiliser :/
That was kinda handy.
Lol Grant, would do that but don't think it'll be such a good idea for Decca.
Eh, they'll be ok with duct tape, everyone knows it's the best thing ever.
Same here, battery in the siren exploded on my Viper, repaired under warranty. The USB rechargable fob is great though.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
