I wonder if VicRoads actually ever moderates the declared value of people handing in transfer forms.
I know plenty of "friends" who under-value their cars by thousands on those forms, and for good reason, those stamp duty charges are ludicrous!
Simple answer. Yes when they get audited, no if not
was raining outside, good time to sand down headlights for glassylite :P
Not a good time for dat nano sealant though...
Give it the full 24 hours without moisture; I let it rain lightly on the nano after a couple hours last time and now have small spots all over headlights that I can't remove until I sand it again.
happy 23k.
yeah parked it in the shed and did the rest in there, rain stopped so can start to take measures for tanks in the boot without getting wet now
Anyone into man powered bikes?
I want to get my first one. Been told a good mountain bike to start on would be a jamis x3 trail.
$600 give or take.
Need to get fit. Advice?
Alvin can build you one with his bare hands
$600 give or take.
Get a hybrid, half mountain / half road.
Easier to ride on bike trails and can do the occasional gravel.
You are not going bush bashing and won't be on the roads as you hate cyclists. You will be sticking to bike trails.
Get an entry level bike for $300, upgrade when you know what you really want and suits you.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
