I wonder if VicRoads actually ever moderates the declared value of people handing in transfer forms.
I know plenty of "friends" who under-value their cars by thousands on those forms, and for good reason, those stamp duty charges are ludicrous!
Simple answer. Yes when they get audited, no if not
was raining outside, good time to sand down headlights for glassylite :P
Not a good time for dat nano sealant though...
Give it the full 24 hours without moisture; I let it rain lightly on the nano after a couple hours last time and now have small spots all over headlights that I can't remove until I sand it again.
happy 23k.
yeah parked it in the shed and did the rest in there, rain stopped so can start to take measures for tanks in the boot without getting wet now
Anyone into man powered bikes?
I want to get my first one. Been told a good mountain bike to start on would be a jamis x3 trail.
$600 give or take.
Need to get fit. Advice?
Alvin can build you one with his bare hands
$600 give or take.
Get a hybrid, half mountain / half road.
Easier to ride on bike trails and can do the occasional gravel.
You are not going bush bashing and won't be on the roads as you hate cyclists. You will be sticking to bike trails.
Get an entry level bike for $300, upgrade when you know what you really want and suits you.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
