Do it a few hundred times and learn to hate it! I have a bag full of fuel pumps in my boot due to the ridiculous amount of times I've had to drop/replace the tank (on my 3rd tank now?) and fuel pump wiring, and fuel pump replacing, and oh jesus nightmares.
you have spare free gtr pump free to good home? :woot:
I can... But I have no materials.
hmm, I need an exhaust hanger replaced. How much roughly do you think it'd cost incl materials?
they aint cheap/free lol. just want gts or gtr for ease of fitment.
Have gts pump you can have for cheap if you're keen
what is cheap sexy man?
(hoping flattery will get him somewhere)
Tony/Alvin/other 34 owners I don't know who, do you have issues with fuel gauge?
Mine is acting funny :/ Mike reckons it's sender that needs cleaning.
Filled up and gauge shows empty with low fuel light on...
Mine i think is ok
I should get one. Haha. Does natsoft update live? :0
Normally it does if sessions times are broken up
I wanna break into 150 on re002 before I change anything on car. Got type r brakes sitting at home. Mate can do 149 on 595ss with a more stock set up than mine. So thatll give me motivation. Haha
You going to do Sandown
inb4 Jonoe part of Nakama crew
I'm still surprised that you haven't given up with this 34 of yours...
tentatively done my japanese beer drinking friend. where would this here pump be located?
In Heathcote, if you go past pyalong and happen to bump into Sgt Lomas, tell him hi for me.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
