Grant, I have a Nissan oem T3 gasket here if you replace it.
Or we could just run no gasket XR6 turbo style. ;)
Excellent, thanks and see you, what time do you want me to pop in? I'm thinking 10-11am?
Some of my mates work at Coles, one is a manager.. I can help you out if you are serious
I might take you up on it after x-mas, obviously need to think things through first.
hitting up gami tonight, dat fried chicken! also apparently half price on the beer. $7 for ~1L+? yes pls. liver has copped it a bit this past week, hang in there also pls.
