affirmative.
Having issues with airflow... turbo is pulsating at idle. Everybody is scratching heads at the moment.
could be out of balance throttle bodies, turbo (while simple, it was rebuilt during build), people are pointing fingers at cams and JUNs lack of info on cam card.
I dunno... will let the pro's sort it out.
After doing some reading on the complexities of the vacuum and hose system on the intake of the GTiR (hooray for Nissan and clusterf**ks), I am liking the idea of a BOV and recirc all those damn hoses. It really is a mess.
Posted Image
You has gtir motor yeah?
painting some black trim parts..
1st coat done / 2nd coat done / go to do the 3rd.. pick up wax and grease remover by accident.. back to the start again..
lol
Yeah so go on that cruise
Vu said I should drive the car for a week to let the paint cure properly when finished
Crushing with the new paint?
Baller.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
