They are mad fun to drive in n/a underpowered form, I can only imagine the wicked times I would have in a charged one.
That being said, going from 86 to my R33 makes it feel like a brutal race car.
Nah not even, If anything you feel more aware and safe on a bike. Besides, I see way more accidents involving cars than bikes.
I wouldn't of expected feeling safer!
:(. hope the poor bloke is alright.
dicey is relative i suppose, as a lot of your safety is up to you when riding, i feel. have to be mindful of anything and everyone. doesn't matter whose fault it was when you're going to come off worse! that said despite not having a huge amount of experience yet, still think riding is excellent fun, #noregrets.
more aware, probably. more safe? debatable i think, haha; car vs. bike, pretty sure we'll always lose out! and more accidents involving cars is a given; probability with the majority.
Yeah i suppose thats the thing, no matter whos fault - you come off, you have alot more chance of being hurt, though people are getting hurt / dieing in some cars which are ment to be safe as f**k.
Nah not as bad as people make it out to be. The longer you stay in the game the more dangerous it is, though. Your riding style and attitude plays a huge part in susceptibility to accidents and sometimes you can be the best/safest rider in the world and have some shit luck when some Asian driver doesn't see you. It's too much fun for you to constantly be paranoid about all that though.
Colourclassic that might be because of a larger proportion of cars on the road lol
Even if fewer motorbike accidents than cars, they do tend to be more serious for even small bumps!
Yeah that pretty much sums it up, the longer you do it, the more chance your number is up..
I can see sensible riders obviously being more aware of what the consequences are and being much safer.
Also the longer you do it the more you can develop bad habits or get lazy with your riding. Sometimes learners are the safest...other times they are the most dangerous. Lots of variables.
One thing for sure though, no one ever died just from getting their Ls, so you should! There's just nothing like the blurriness / slowing of time you get from riding a super sport!
I dunno, I guess the heightened awareness from lack of A/B/C pillars, radio and a higher outlook makes me feel more in-touch with what's going on around me, so I feel safer. Is it actually safer in a crash? Narp.
That said, I don't really ride on the road much these days, it's no fun compared to track.
anyone recommend a place (turbo?) to purchase garett turbo compressor wheel/housing and machine works to fit to existing turbine...? Not ATP. Got nothing against Kip, just think this job is beyond our communication skills.
Rotormaster, was told they're the one to see for Garrett turbo
Drove my mates stock BA XR6 turbo today, was painfully slow. Should it feel quicker than a stock-ish Gts-t?
No, but it should fall apart quicker than stock-ish gtst.
Inb4 Germain and glover.
When I drove one of these I was quite disappointed after all the hype they got. My GTS-T with exhaust did indeed feel quicker. Could have been a shoebox though...the guy was running it straight off the turbo no air filter lol
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
