decent breakfast in the back of Balaclava... http://www.monkbodhidharma.com.au/
my old housemate was complaining because they wouldnt put bacon on his breakfast "what kind of breakfast place doesnt have bacon?" A vegan one you f**king moron.
on the hunt for local decent breakfast this morning, but too many bayside cafes are packed full of tards.
Just checked out Chin Chin on the net; yes this looks like the kind of place I'm looking for! Ta :)
I dont think they take bookings and there is usually quite a queue
Just letting you know in advance
Go early!
08 a5 3.2ltr 6 parking system works when it feels like it, drivers window sounded like a chainsaw opening and closing.. Engine oil disappears like no tomorrow engine codes come up for no reason been real pain in the ass lately
All said the car drives like a dream as I said it's just little niggly shit but to me it shouldn't happen on that kind of car all my mates BMW / mercs no problems at all
Get an a45 amg best 80k you'll ever spend!
Yeah shouldn't happen with premium $ cars... Does put me off a bit even though it's the first I've heard of issues with Audi, not that I ask a lot of people though..My mates A6 hasn't had any issues yet but he hasn't had it that long yet, only a couple of months...
Just looked up the A45, if it wasn't a hatchback I'd be more interested....C63 would be the ultimate for me... Second hand 4 doors would be around how much?
Otherwise a newer model M3, black on black. Again though, haven't looked at prices so might be too much...
Lygon st. Can't go wrong. Taken a few ladies there
Pimp
Problem is not many newer cars do it for me these days...
Audi A5/S5. A5 shape looks sick when done right, but S5 would be good for some performance
M3, but don't want the older model every leb and his mate has
C63 AMG, top choice but probably too expensive or 300,000kms for a cheaper one
34 GTR, goes in a completely different direction to the ones above, half the price, but I'd probably spend more on it..
If you recall, we were going to go to Chin Chin on the night of our beach visit, but Aaron and Jess bailed and it was getting late so we called it off.
We've been to plenty of awesome restaurants in Melbourne, the biggest issue of all is that they are awesome for people who eat meat...like most restaurants. I can take you to plenty of well known / reputable vegetarian places...I just won't eat anything there!
Yeh amg c63 under a ton is do able but it'll have high kms
The a45 is awesome don't judge it from outside the interior is better then the c63!
I know of heaps of people with audi trouble man
No, most of the places you have taken me have also had average atmosphere and service. The 2 awesome places I've been to have been Chandon and Conservatory.
there is an A45 amg with the full kit that lives near me... thing is tits
Because everytime I go to take you to an awesome place the vegetarian option on the menu isn't good enough or you already had that the night before and we leave! Like I said, if you want awesome veg only food we can do that - I've taken you to places that I know are great for people who eat meat; also taken you to places that I haven't tried before for the sake of trying something new for both. Reality is, it's a bit hard to pull off anything when one person likes mostly meat and the other won't touch it :)
Our city has a rep for playing host to some of the best restaurants in the world...which counts for nothing if you can't eat most of the stuff they whip up there.
If they are some of the best restaurants in the world then they will cater for everyone.
All I want is to go out to a cool restaurant like I do at home.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
