Your ass getting sore from sitting on the couch (yes sitting on the couch, I'm not implying anything else) this summer...
List of SAU VIC Events for Q1 2014.
http://www.skylinesaustralia.com/forums/topic/437237-welcome-to-2014/
No excuses, I'd seriously be putting September 28th aside btw.
well now FPV is dead, the GT motor coming out in the XR8
so priced just over 40K new.
oh the 335, it has an over boost feature so if you give it a prod it does 375.
that's some bang for your back.
and considering the 2 AU built cars I've ever owned have been the ones that fell apart more than any other, great engine or not I think I would pass.
I'm sure when the FPV were done "bespoke" they were much better, but now they assembly line things, meh.
got a hint for us richo?
40k for the 335 supercharger engine? if the interior is elevated above taxi spec this would be fairly awesome - not a massive ford fan but that engine is amazeballs.
:wub: ham!
I've got heaps of spare hubs if you want one huy
Got to see if the other ones are broken or not, not too promising when two studs on one is broken.
Richo, will post photo of tyre later tonight.
one, more, have a pair of fronts and 2 pairs of rears I'm never gonna use.
i maintain my opinion that the new 5L ford engine is awesome. so easy to make power out of it.
oh I agree with this part
my mate may have one for sale as he is shooting for 1000hp and using a crate engine if your interested :P
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
