Your ass getting sore from sitting on the couch (yes sitting on the couch, I'm not implying anything else) this summer...
List of SAU VIC Events for Q1 2014.
http://www.skylinesaustralia.com/forums/topic/437237-welcome-to-2014/
No excuses, I'd seriously be putting September 28th aside btw.
well now FPV is dead, the GT motor coming out in the XR8
so priced just over 40K new.
oh the 335, it has an over boost feature so if you give it a prod it does 375.
that's some bang for your back.
and considering the 2 AU built cars I've ever owned have been the ones that fell apart more than any other, great engine or not I think I would pass.
I'm sure when the FPV were done "bespoke" they were much better, but now they assembly line things, meh.
got a hint for us richo?
40k for the 335 supercharger engine? if the interior is elevated above taxi spec this would be fairly awesome - not a massive ford fan but that engine is amazeballs.
:wub: ham!
I've got heaps of spare hubs if you want one huy
Got to see if the other ones are broken or not, not too promising when two studs on one is broken.
Richo, will post photo of tyre later tonight.
one, more, have a pair of fronts and 2 pairs of rears I'm never gonna use.
i maintain my opinion that the new 5L ford engine is awesome. so easy to make power out of it.
oh I agree with this part
my mate may have one for sale as he is shooting for 1000hp and using a crate engine if your interested :P
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
