Hey Dezz, come work in the mines. Big money if you don't have family in mind.
Nah not for me. Sure you can make some cash but f**k that working 2/3/4 weeks straight shit 12 hour days etc...If I worked those hours here I'd make the same amount of cash...
I can make enough here to keep me happy without having to move to the desert and have no life..
  • Like 1
the spray gun and liquid wrap arrived today. looks the goods! I'm pretty excited.
went to autobarn and grabbed some plasti dip glossifier. all plasti dip stock is $30, was pleasantly surprised. however they wanted $240 for 3.4L of the non aerosol paint :/
Anyone know a good machinist/turner that can cut some new circlip rings in my Bilsteins? I'd go to Quadrant but they want $35 a cut and are out in Berwick which is a trek for me.... Closer to inner suburbs would be bettahhh..
true that, you would have to work 2 weeks on (1wk Day & 1wk Night) & 1 week off.
However if you do the maths... 2weeks * 12hrs = 168hrs worked over 3 weeks (2 weeks on + 1 week off) = 168hrs / 3weeks = 8hrs/day (incl weekends)
So it works out to be 8hrs/day on average (over the year) but you end up on a salary around the $100,000 - $200,000 mark - http://iminco.net/mining-job-salaries-how-much-can-you-earn-mining-careers/
but you're only home every 3rd weekend if you look at it from the other side haha
...and you have to move to Perth, who would do that :P
Spieth Engineering in Baywaster has cut circlip rings for Bilsteins before.
  • Like 1
So thread has been inactive for two hours.
I'm watching a doco about the Fairlady Z on youtube. Just mentioned the fact that the Korean War was basically what kept the Japanese car industry and Nissan in business. So without the Americans, we wouldn't have Skylines.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
