Pearls are amazing, especially the black ones but I would only wear wild pearls lol
whys that? and how do you know theyre not lying?
Leroy,
interesting article on how to get a SR powered FWD 2 sec faster down the Quarter for 0$
think this could be a valid test for you.
or any hatchback really...
http://www.nerocam.com/SCC_TAP.asp
lol worlds first convertible N15. i'd try that.
Question: what rights does someone have if they're being forced to go on call after hours for their job? like not initially in their PD or contract?
Just man up and grab that extra cash.
on call (to me) usually means: vehicle with private use or minimum call-out 4 hours (OT), or weekly allowance for period on-call or minimum 10hour break between shifts (and paid stood down time if overlap with normal work hours) OR all of the above. But depends on how many call outs a month there is in the industry.
There is extra cash but not enough to make me / other guys that were offered the same thing to take it lol
edit: It's I.T so most can be done remotely but yeah, I enjoy not having to worry about anything on the weekends.
Edited by UNR33L
FKN GEN Y
If you guys spent as much time working as you do acting like the world owes you something we'd be paving the streets with gold
Angry old man.
Just cause you had no choice back in yer day doesn't mean it was the right thing. :P
Dat work lyf balance
  • Like 1
FKN GEN Y
No we wouldn't gold streets would be dangerous and Vic roads wouldn't allow it
FKN GEN Y
Being on-call means you cant drink during your week, must be located a reasonable distance from possible call-out locations and have to carry any necessary tools with you whenever you leave the house.
its a pretty big inconvenience.
When I last did on call, we got $$ for the week on call, plus 4 hours TIL min for any call out,
was IT as well, so did not need to be onsite so long as we could log on within 1 hour was all good.
And laptop/phone with data meant we could do it anywhere.
and not hard to be sober enough to troubleshoot a unix box.
I used to love it as I would not budget for the cash, so was free car parts!
eh? you don't eat meat, but wear pearls?
Wild pearls... not farmed pearls...
And no I don't wear pearls because they are cultured. I said I would only wear wild pearls if I wore them! (which won't happen because they are too rare lol)
Edited by L33SH
sudo rm -rf ?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
