Nah on the old Sun Ultra 10's just give the HDD a good work out, it would then fail and it was vendor issue not mine....
just kidding..
but a well set up system should not page very often.
and if you have some redundancy then even easier.
was there for 36 hours straight once rebuilding an exchange server, got me a week off for that so score!
Wild pearls... not farmed pearls...
And no I don't wear pearls because they are cultured. I said I would only wear wild pearls if I wore them! (which won't happen because they are too rare lol)
wild pearls still involves killing them oysters/mussels no?
Yes; I guess where I'm coming from is that wild pearls are a natural process, wheras when farmed the irritant is placed inside the oyster shell to create the pearl. But I guess any sort of pearl is cruel
well, cultured pearls are still based off a captive population of oysters/mussels collected from the wild.
They are given a safe haven to live and breed, with an irritant inserted that does not affect any biological functions. As a pearl takes ages to grow to marketable size, a lot of them live longer than they would in the wild, and all of them wouldn't even know the difference. Also, meat/shells are reuseable. Shells go into the production of lime, and meat is sold as food/animal feed.
So, its debatable as to wild or cultured is more cruel. How do they determine if a wild oyster has a peal in it anyway?
  • Like 1
not entirely true, you could find a pearl in an already dead mollusk. hadnt thought of that.
But mollusk and tree fall into the same category for me.
you could, but then they'd be blister pearls and aren't your usual spherical pearls. not really of much use to your jeweller.
was not aware of that. assumed pearl would be retained ok since... its a pearl.
get to pick out the pearl tomorrow. not sure if fresh or salt water :| first world problems.
if you're looking for chains, go to one of those asian jewellers @ springvale or something, they do cheaper chains. and a chain is just a chain.
remember paying 118 for a 18k white gold chain when i got my then girlf an overpriced piece of shit tiff n co key pendant.
Edited by xALmoN
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
