sure Calder on the 8th?
I still need an oil cooler and fix my suspension for that :/
can I drive
Maybe if the cars not such a handful
I will join teh queue. 385rwkw?! That's crazy, let us know what it's like to drive..
Yeah haven't had a chance to boot it yet. Little scared at the same time
Will be interesting if the hankook rs3 265's and standard diff will be able to cope
need a good wallet leather wallet, need brands and places to buy (not fossil please)
k, go.
My last was a nice Ben sherman one from Myer.
had the drivers license in a pull out with 2 card slots so if you want to travel light it was a good convertible.
have a fossil now..sucks massively no foreign currency fits.
oh btw brahs need advice, D2 racing coilovers or BC BR (gold) coilovers? my hks ones are on there way, one of the shocks is kaput and leaking. :/
Nfi on D2 Racing.
I've BC BR in my 34, can take for spin if you want to see how the ride is, I suppose. No complaints about them from me, anyway.
I would have said 4 minutes but I added an extra minute cause hub dyno
Dat speed hub dyno dependency. You forget, however, if he uses the gutter he'll be able to take corners even faster. #FujiwaraTakumi
Rip Curl
Back 2 High School.
I'm happy with my Oroton wallet.
  • Like 1
man up, i had a few more watts, and what it is when you put the foot down is fun, and mildly smokey.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
