I don't really care I flog it anywhere now, dat non import lyf
fkn this.
I gave up caring when i got my SECOND speeding ticket for less than 5km over.
if they are going to book me anyway, I might as well do what the fuck i want
Not that I doubt Damien's abilities, but unless he can add a 4th dimension to the universe, I can't see the reflection being any deeper/better than a pure mirror :P
Artz and Birdz detailing ftw
looool
Don't you have an r33? You'll need side feeds if you aren't doing rail conversion
This. The ID website said the ID2000's are for RB25/26. huh?
I've heard 1000cc + injectors can cause idle issues using a PowerFC on PULP? Of course if going e85 I'll go ID's..
I've got ID1000's and it did have some idle ups and downs occasionally with PowerFC, but that was with trents tuning (wasnt harmful or anything). Been elsewhere and havent had the issue.
Id1000 brah checkin in
Go big injectors and do it once
You'll eventually upgrade in the future and want headroom if you ever go e85
Dino fuel lover to e85 guru in 1 tune session. My work here is done. :P
weird. he knows exactly what causes that and usually corrects it... was he in a rush for that tune?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
