word on the street is tony was like gotye at the arias today?
I was just lucky Birds didn't show up in his mirror car :/
Lol wut?
How many awards did Tony get? Well deserved anyway, cars very noice.
Thanks Anna. Just 2 :)
Need some help guys, my car is insured under dads name but he's overseas atm and won't be back till mid march. Can I still call them up and tell em what's happened?
What's happened?
My 4 door was insure in my dads name, when I was run into I handled all the insurance stuff as I was the one driving. Just make sure you don't slip up and call it your car :P
  • Like 1
Thanks brah.
Have had a shit day, went outside to warm up the car and raged...Car got egged and a lot of it...mainly egg yolk too so two spots of the paint have peeled off completely and other areas have been embedded with it so I need to get a respray done :/
Yeah you weren't driving so can easily initiate a claim on your dad's behalf if you have the details. Might need a letter or proxy to concrete anything, though.
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
