Good location thats all i need to know
Wanted to stay at Orchard rd area but a bit exy
One day I'l stay at the Marina Bay sands when I'm a high roller
Are people allowed to go into that hotel up to the top for fun? Or you need to be a guest/pay etc..?
you mean here:
yeah only guests can go to the pool, there is a bar off to the side at either end that visitors can go to.
Doesn't matter what you put the sticker on, as long as you're not trashing it and generating a bad perception of the club...
Do mike, remove your sticker please.
sad..but mines on my luggage,
some-one tried to walk off with my suitcase one time, so I'm slowly sticker bombing it to make it stand out.
nice,
we goign a week later as
1 want to avoid school holidays
2 as thought VIC time attack would be easter again. (but they changed date to weekend we now fly out!)
3 katie struggles to get public holidays off
heading to krabi for a week, should be fun.
yeah it insane,
I purposely picked a non black one as had probs in the past
So got a blue one. now it seems every-one getting blue ones as black too common, so finally there was some-one with the same one.\ and yeah they started to walk off
So car stickers to identify it,
think will get one of these next tho, and might get it airbrushed..
https://www.samsoniteaustralia.com/bag-finder/travel-hardside/firelite.html
Fixed my wind deflectors today. The clip closest to the front quarter panel came off and the tape was dry, so when I was on the Westgate freeway doing 100km half of the wind deflector came off (looking like it was going to fly away). Lucky it managed to stay together.
Had to completely remove the double sided tape (bitch of a job, still couldn't get 100% of it off) and put new tape down. Also adjusted the clips so now it's completely secure ;)
want to try.
Sunshine two strokes sound awesome fun, but south morang has a great track. wasnt sure if you could hire karts there though
Are you free this weekend? We are doing Go Karts at Ace Karts starting at 10am :)
I've done LeMans, Ace, Auscart so far. There's one in Epping but don't think it's pop in and drive deal.
Also there's couple up north in Somerton and South Morang from what I was told, yet to check it out.
Oh go karts is definitely something I want to do soon!
Used to go a lot when I was younger but haven't been for ages!
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
