ehh rwd more fun!
I seem to recall some bloke telling me to drop my shaft in GTR and drive a 'mans' car :P
Birds saw you turn left onto FTG road this morning was at lights waiting to turn right. /csb
Will have to keep an eye out for you, I thought you left 10-15 mins earlier than I do.
Drivers be all like, it's wet on the roads I better drive 40km/h slower because I'm such a shit driver that I'm likely to lock up my brakes in the wet.
Love straight out exhaust on almost any car just to see how natural and beasty an engine can sound. Used to do it to most cars I'd put up on the hoist.
But gawd, the day I took the mufflers off my R1 and started it up. Shit shook my car port.
short pipes/side pipes = hnnnng
normal exhaust length without muffler/cat or hotdog = pretty terrible. DECA is all about SR's and RB's with no mufflers and they all get kicked off track days when they go to a circuit. half because loud, other half cause sounds bad.
yea 160kw, 4wd. picked up an 02 for a steal.
can pick up classics for sub 5k, cheap fun.
The wrx club only allow turbo subies to join up. The 3.0RB has 180kw, but is ineligible... go figure
i know is bullshit.....
we can be in a club together mate. you with your 3 litre and me with my auto.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
