Yeah but don't understand the idea behind it, is it incase bike slides off don't want the originals wrecked?
This plus general scratches from shit flicking up from other bikes and your own, plus eliminating roadworthy items you don't need that are just deadweight. Sure I've left out a few reasons.
skiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiids.
and by skids I mean searching for front wheel traction.
should stop procrastination and take the dash apart to fit rev limiter and shift light...
dezz how come you changing all your fairings around to the white ones??
because trackspec i'm assuming
Fiberglass is cheaper and easier to repair...Has no lights etc, easier to get on/off quicker once fitted.. etc
On that note, any design/creative kunce that wanna photoshop some color schemes onto that photo, knock yourself out..
I'm leaning towards predominantly black with maybe some red/white highlights/sections, but feel free to change my mind with your designs.
The winning design will receive $5.
needed a new battery. of course place sold their last one 'just last week'. because of holidays etc looks like it will be late this week to get it, if that.
so impatient for these little things, urgh :(
I suppose. I don't think it's excessively crazy. But he did sink some money into it.
Called Autobarn, they wanted $399 for the battery haha jebus. Who actually buys at such a ridic price.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
