I dont watch the show but read up on The Red Wedding.
damn... I probably would have given up on the show then and there. Im all for characters dying in a show, it adds originality... but evil should never go that far and destroy hope of any good.
It's good isn't it...
So good.
let em spoil it for you..
voldemort kills most of them
but then they blow up his death star.
Haha, I should mention, I've long since read all the books, just never got around to watching the tv series in its entirety.
So besides the liberties the show has taken in comparison to the books (though, with much input with GRRM I assume) nothing is really a surprise as per se. Still awesome, though.
Haha, followed by the Purple Wedding, which just happened in the show.
But yeah, the Red Wedding was pretty brutal. When I first read that chapter, I was just like... wut. O lawd.
strange I thought the V domestic lounges were meant to be better than the Q ones,
that said I have been told the lounges in Perth are not as good due to nearly everyone having access (FIFO perks) that they cheapened them down.
Haha #partoftheproblem.
Everyone in mining industry automatically gets gold status.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
