You can bid for virgin business class these days, if they have spare seat...minimum bid $350...almost worth it on a Perth flight. I had a bid in, but retracted after automotive repair bills came my way.
Just got platinum cred and they must have had some spare seats in business.
Points are saved. When is the next trip? :P
Which bank is this with?
With Westpac you get access to the Priority pass lounge at airports which is handy when you got interchanging flights
So free lounge, food, desserts, drinks, alchy, showers etc...
They neglect to mention this treatment on the platinum cred section of the website lol
I should be a silver by the end of the year, by off my own status credits and hard earned money :P
If you keep going you can get plat for life I think? Like 7000+ status creds
Dunno when next trip but I wanna go back soon. Will have to tee something up with Jay for dat free accommodation so I don't have to bunk at a brothel in little India :P
Haha sorry we all can't stay in private villas/estates with maids and shit. :P
What I meant was that I've reached platinum frequent flyer lvl.
Yeah i know, just didn't know which bank it was in relation to, so didn't know the system level/benefits
At Westpac we have 3 levels
Altitude
Altitude Platinum
Altitude Black
I'm on black no rascist
VWYMCMB
lol you get the free luxury flights, I get the free luxury accommodation!
Maid wanted to carry my 25kg case up the stairs...
  • Like 1
Altitude
Altitude Platinum
Altitude Black
VWYMCMB
Subtle change of employment
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
