#@blah_blah #@kaitoukid Do either of you have S1 reo for cheapish, and can drop to me in Ringwood or Dave's in Franga tomorrow? I'd come pick it up, but my car is at Dave's.
Neg, mine is on car haha. However...
I have a r34 series 1 front reo if you are going to get another one
Better food than USA as well
Kinda scary seeing a beer just wander out of the trees tho
dem wandering beers doe.
Dave said I don't need one, he's managed to hammer it out. Will still probably acquire one eventually just in case. Also did you quote me saying things I didn't, or is the app being retarded?
Dat structural integrity...
They are only made to take one solid hit and if you can hammer it out again it's prolly in a weak as fk state; and weaker again now that someone has taken a hammer to it. So if you care about the crash zone and legality replace it...otherwise, carry on.
Yeah If you want to drink cocktails on a beach then yeah, Fiji. We went to cancun, in Mexico and it's got an amazing beach if you want to do that
as it is I probably be forced to go to NZ sometime as missus has family there and used to holiday there alot....but it will be against my will :P
anyone recommend a painter/powdercoater for wheels?
not going back to A1 powdercoating in moorabbin.
I was advised a while abck by a powder coater not to powder coat wheels if its a race car....they dont like heat...
which is odd considering everybody thinks powdercoating is the bomb....
Anyway another option...come around some time...bring beer, you help me sand em back Ill spray em for you...save a few bucks that way,, ;)
I keep reading that and it sounds pretty dumb to me. Something along the lines of 800 degree brake dust flying around plus hot tyres making wheels get hot too... Though they are spinning and cooling down, and the heat usually even (as oppose to section by section sandblasting)
I am keen, and am interested, but im not even sure if the bronze can even be sanded off since its not smooth like painted wheels, its quite rough almost like golf ball dimples.
Toby, are you still the treasurer?
If your requesting a refund, i've spent it
Well missus wants to go tas or new zealand in July... anyone here with experience, yay or nay?
New Zealand, Queenstown. Could do a drive down from Christchurch to Queenstown with a stop over at Lake Tekapo. Amazing scenery.
In saying that, airasia flights arent that much more exy. And money spend extra on flights would be saved via accomodation, food and spending costs anyway.
Everything in asia cheap cheap
I do, but no time to drop it off
meh its fine man....f**k most peopl cut them out and put intercoolers in anyway....just shuddup birds...stop making him worry .its only NA not like it will go fast enough to do any real damage anyway :rofl:
I cut out half my reo with a grinder to fit cooler; cop remarked to me that it was good I hadn't cut any holes in the chassis to for my return flow lol
Just sayin he shouldn't worry about the bump that was already there, if he's not worried about your "customisation"!
yeh i flew into christchurch and drove down, nothing left there after the earthquakes which was pretty sad this was almost 2 years back i think so might of changed.
Things seemed normal pretty much, i was there last year in about October.
Did you eat at Fergburger in Queenstown? I had that for breakfast lunch and dinner. Best burger I've eaten
my sisters bf just got a job as manager for the project of town planning for rebuilding christchurch.
theyve start rebuilding some of it... as most were insurance claimed/government, but if the block of land has a height difference of 30mm or more at the ends then its has to be demolished and rebuilt :unsure:
a lot of the older buildings theyre keeping the front and rebuilding everything behind it.
from what it used to be, or just across the block?
My block has 20m difference front to back :D
Yeh think I had it once over there, we were only in Queenstown 2 or 3 nights I think from memory, should of had more time there.
Did the jet boat thing ini the canyons which was awesome too
Well, looks like it's 6:30... guesss I'm not going GC meet. The gym ( :yes:) and hw ( :no:) beckons instead.
Also on topic, lived in NZ for like 7 years, but wasn't old enough to do anything cool or suggest any cool locales :/. Would definitely rather go there than TAS surely, though?
Or better yet, just go Japan dude. Your wallet won't thank you though. But your heart will.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
