I thought you sold your 34 ??
Mad props to Dave for the awesome work he did. He also made it really shiny. Just gotta give it a wax.
i was going to do it today but run out of time
just wait till you come back and we wax it then :thumbsup:
Well, looks like it's 6:30... guesss I'm not going GC meet. The gym ( :yes:) and hw ( :no:) beckons instead.
Also on topic, lived in NZ for like 7 years, but wasn't old enough to do anything cool or suggest any cool locales :/. Would definitely rather go there than TAS surely, though?
Or better yet, just go Japan dude. Your wallet won't thank you though. But your heart will.
I was down there from 6:15 - 7:45 you would have seen me but was shootin hoops for most of it
fair deal. i'm just about to leave for it, avoiding peak times lol.
oh...what is it?
lancer
Why are there still so many morons to this day that bid on eBay auctions with no reserve, 9 days in advance, so instead of having a bidding war at $50 dollars, they have a bidding war at $5,000 dollars 1 hour before the auction ends.
GOTTA GET IN EARLY, I MIGHT MISS OUT!!!
It's great to jump in at the last 10 seconds with your maximum bid cus they've been doing tiny bids the entire time.
lol...
why do people start bidding wars at stupid low prices...then spend the next week getting there mates to pretend bid on it to drive the price up...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
