^ thinking about going there but too scared about knox tmu after the last meet that was held there :/ they were at all the exits
well if your car is rwc...why worry?
sif be scared of tmu...just smile and nod politely as you do what they ask, then leave and do what the hell you want anyway
always rely on much worse cars than yours to steal the spotlight. have seen bagged R32's scrape on modest carpark entrances infront of cops and they just watch to make sure no one does skids.
Still got all mine from when I was a kid, (plus lots more now an adult) and none of the wheels came off..maybe you had fakes??
remember stress testing them by running volkswages over with bigger and bigger machinery..still want to do that now
I've still got some of mine, think my dad threw away some of them.. Will never forget that day!
Maybe I was a brutal child hence why the wheels falling off, maybe it wasn't the hotwheels & matchbox ones that fell off. Prob something else then.
yeah only kids toys I kept were my cars, lego and a couple transformers.
wish kept more but too played with to be valuable.
yeah I got bored started riding over them with my push bike, moved to dads motor bike, then the car, then the farm ute, through the different tractors then finally staging them for when the milk truck would arrive.
damn I hated VW's! but all the multi packs seems to come with one
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
