I got them in a 255/40/R17
2 laps in and they were just spinning in every corner.
that's with 180kw at that!
I'm currently running at about 250-260rwkw with a nice smooth power curve so nothing really comes on too hard too fast, and the car does mostly street driving. I'm really happy with them because of their bang for buck ratio and their cold grip which is where I mostly use them. If I was taking it to the track then I wouldn't be using them, because as you say, they go off after a few hot laps and need to cool down.
They do smoke nicely at deca though ;)
Using the basketball court for a motorkhana circuit instead of the megamini, tyres do not like it very much...
Also, need rear camber arms :/
tried to claim me some centerlink yesterday.
apparently i earn to much or someshit, but every little helps. have to take the visa in and see what they say.
Im pretty sure Centrelink payments are exclusive to GTR owners only now
Sorry brah
nice nankangs bro...My cressy rolls on nankangs :P
My plan was... Nankangs on the 17's for pottering about, Stickies on the 18's for track grip...
Though it seems whenever it goes to DECA or Track the 18's go on, and then don't come back off for street driving because the BBS's look better than the AVS's.
*sigh* so it looks like I need to wait up to 4 weeks before my car is repaired again. The parts have been ordered from Nissan Australia and that's the estimate they gave to the repair shop.
Anyone ordered from Nissan Australia before? How long did it take?
Sounds about right.
Smaller parts will get here sooner.
What happened to the car? What parts take a month to acquire? Gotta be coming from JP at that timespan...
Was involved in a rear end collision. Rear bumper, 2 rear reverse lights, the back panel and a few others I think. Yep they are coming from Japan, I'm hoping it is more like 2 weeks delivery.
In the meantime spend your petrol money on alcohol, hookers, bet on black, buy crack, and moar alcohol
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
