I got them in a 255/40/R17
2 laps in and they were just spinning in every corner.
that's with 180kw at that!
I'm currently running at about 250-260rwkw with a nice smooth power curve so nothing really comes on too hard too fast, and the car does mostly street driving. I'm really happy with them because of their bang for buck ratio and their cold grip which is where I mostly use them. If I was taking it to the track then I wouldn't be using them, because as you say, they go off after a few hot laps and need to cool down.
They do smoke nicely at deca though ;)
Using the basketball court for a motorkhana circuit instead of the megamini, tyres do not like it very much...
Also, need rear camber arms :/
tried to claim me some centerlink yesterday.
apparently i earn to much or someshit, but every little helps. have to take the visa in and see what they say.
Im pretty sure Centrelink payments are exclusive to GTR owners only now
Sorry brah
nice nankangs bro...My cressy rolls on nankangs :P
My plan was... Nankangs on the 17's for pottering about, Stickies on the 18's for track grip...
Though it seems whenever it goes to DECA or Track the 18's go on, and then don't come back off for street driving because the BBS's look better than the AVS's.
*sigh* so it looks like I need to wait up to 4 weeks before my car is repaired again. The parts have been ordered from Nissan Australia and that's the estimate they gave to the repair shop.
Anyone ordered from Nissan Australia before? How long did it take?
Sounds about right.
Smaller parts will get here sooner.
What happened to the car? What parts take a month to acquire? Gotta be coming from JP at that timespan...
Was involved in a rear end collision. Rear bumper, 2 rear reverse lights, the back panel and a few others I think. Yep they are coming from Japan, I'm hoping it is more like 2 weeks delivery.
In the meantime spend your petrol money on alcohol, hookers, bet on black, buy crack, and moar alcohol
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
