Depends on lines; with baggage, the earliest, I call 8:45.
If you're trying to skimp on airport parking then park at Maccas and wait for phone call...or chance your 20 minutes in the wait and collect zone on the way to terminal 4.
Or do what other tight asses do and pull over on the Tulla pretending to be broken down lol
The maccas outside the airport can be a pain for parking since all the chauffeurs park there... Try getting off the exit before the airport, there's a much bigger maccas just at the exit. Think that exit is called mck something.
thats a kinda busy time at airport, on a plus note it means more ppl working. lucky it just b4 a 380 but if her flight delayed it will push out quickly.
I normally go with 30 min.
that said I have been in a taxi in under 10 min from landing once!
make sure you track the plane to know the actual landing time and then work with 15-20 min from that.
RS5 y u no drag me. You didn't buy the sports model, you bought the racing model...why do this if you're gonna take off like a Hyundai Excel. Did the smell of burning sugarcane scare you?
Answer me!
Answer me!
ill drag you big fella.
just gimme a while to sort some tyres.,....
speaking of. anyone know anywhere around dandy area that can open the centre bore on a set of wheels?!
Answer me!
RS4 was no racing model when I drove it, my guess is the RS5 isn't much better.
even worse this morning
but when you command a 350kw battle ship nothing is a racing model :woot:
Perhaps. I just expected more.
I think it needed twin turbo and ethanol, but there just wasn't room, and it was a hatch so no boot. :P
only rs model ive ever driven was an old rs6 wagon from (i think) early 2000's. was a mint car on das autobarn.
Take the "Freight" exit, which is currently used for the Long Term Parking, on your left there will be a waiting area designed specifically for people like you who just want to hang out and wait for planes to land so you're not doing laps constantly or clogging up maccas.
http://melbourneairport.com.au/news-events/listing/overview/ring-ride-waiting-zone-.html
Mickelham Rd?
This. I sit in the car park till i know the person has collected baggage, then sit in pick-up zone waiting for them. If you get kicked out, do a lap round the block and start again.
BRING IT OOOOOOOOON
Meh, I just don't drive to the airport since it costs me $80 in fuel for the trip.
Came back from Sydney on Monday... Long Term Car park from Saturday 7am until Monday 11am cost me $70 (3 days).
I seem to remember leaving the car there for a full week once, and I think it was about $90... Blergh.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
