Thought those kits were like $6k...
I would go supercharger, but only if roots type. The centrifugal ones are basically turbos anyway, just a little less laggy.
I think the turbo will be more fun and a roots blower better for drivability when you want to fang it.
Yeah basically!
Umm... both? hahaha To be honest, I'm not even 100% sure what I want, all I know is I have boost withdrawl symptons ever since selling my 33 and in search of my next boost hit :(
Reading this, go the turbo...it's obviously the spool and sudden rush of power from a turbo that you miss. Blowers are a more linear in their delivery! Though that centrifugal type will have a bit of a come on.
just pm him is all im saying.
mine worked out to be shockingly cheap.
I'm just assuming it's going to be way too much of a headf**k, especially with the crossover pipe from cylinder bank 1 to cylinder bank 2. Not doubting Scotty's skills, just trying to save him from a major headache haha
Yep, they're the eaton-style chargers and not the centrifugal ones (fake turbos I call them hahaha). I'm looking at the Magnuson MP2300 charger with 60lb injectors so I guess the $6k kit would be the ones with no injectors and using the smaller MP1900 charger :)
Turbo for that GATE
You boys are NOT making the decision any easier hahaha
Lumpy cam in a V8 with screamer? Should sound ok I guess haha :whistling:
VE GEN-TT Intercooled Twin Turbocharger Kit $ 7,995
if they sell for this in aus. they can be had for half price from overseas.
very easy to fit too.
Half? No way! Customs and freight will ream me to about the same price anyway won't it?
Also, I'm a f**king noob, I can't install that shit haha
Hahaha, yeah that's the only thing that is making me think supercharging, cos even though I LOVE the violent-ness of a car coming hard on boost with a turbo, the crappy commo would struggle to put that power to the ground I rec kon, even though it weighs almost 2 tons
If supercharging seems more straight forward and still retain the drivability, just go for that.
lt's still the same power out put yet can still use the power, for you setup.
someone say blown v8?
In my experience from actually owning turbo vs supercharged cars, I LOVE the 'rush' of power a turbo gives you (for me was my 33 GTR) but it has absolutely nothing down low, a v8 might fix that.. but you can't beat dem feels of full boost off idle too.
Making like 200+ rwkw at like 1500rpm means you can beat things without going over 3000rpm :D (ofcourse I'm only talking PD superchargers)
Around town / daily spec / less cop trouble supercharger ftw hands down love taking off from the lights no effort at all going through all the gears and being 100m infront of any other cars, fun / weekender I'd go turbo for the more 'lols'.
Around a track I reckon supercharger would be better with predictable power and straight curve, for skids can't beat supercharged v8 either :P
Both sound cool in their own way, I think turbo sounds will cause more cops to look at you though.
Edited by UNR33L
Do the SS's respond to strapping a charger on + tune as well as your GS did?
would make roughly the same power from what I've seen, biggest difference is my engine comes with the supercharger fitted on 'low' boost whereas an SS you're forking out another 10k basically. (not including supporting mods like exhaust etc)
the fact mine came with it from factory means cops can't touch me too, which is nice.
Edited by UNR33L
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
