I run 34 rear, 36 front for daily driving,,,
Driving home today my oil pressure went bye bye on the gauge, engine is still running, think its the pressure sender unit. Bah, so annoying to get to :/
Brashes
Oh and while we're being old...
Remember when the Matrix came out? How cool it was and the amazing CGI? Babies from then can drive a car now.
remember when marty mcfly went back to 1955, how old timey it was....
If that film was made now, he would have traveled back to ~1985
hamish
are you meant to run same pressure at all 4s?
according to manual
fronts 31psi
rears 27psi
first ive heard of it
I usually run same same in the evo as traction is not an issue
tyme for sarnie plate, oil cooler and aftermarket gauges.
Did it again in the middle of my drive to work this morning. Bah.
Already has the OEM oil cooler deleted, using N/A coolant hoses around the block under the intake runners. A Tomei Thermostat unit directly on the side of the block, a Tomei filter relocator and a big oil cooler in front of the Drivers side wheel.
Need to bung in my oil temp sensor to the tomei thermo, replace the stock pressure sender and then I'll be Happy as Larry
10506675_10152068103611148_3939969532096
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
