You can do that with a GTS-T though, to much the same degree...injectors are my only give away cause I cbf spraying them the standard colour.
Return flow IC is legal as long as you don't have a pod.
When I drove a GTR I wasn't impressed. Maybe it had been talked up or I don't hit the corners enough to justify having AWD, but having come from a well sorted GTS-T, I wouldn't pay the extra money.
same..GTST is a much more usable daily car....Im sure the GTR comes into its own at high speeds though and deadly launches...but for a daily driver around town...NAh
the GTr does wonders for the ego though ..
Technically it's an intake mod, so if combined with FMIC, then it's illegal
so case scenario you cant source a second hand rubber intake, they dont make them anymore and they all fall apart...Am I supposed to an expensive engineer certified exemption to put a modfied intake in? there has to be be some leniency there...the rules are f**king stupid, which is why nobody abides by them...on the other hand people are f**king stupid and thats why there is laws....
so we have f**king stupid people making stupid f**king laws for the stupid f**king people to not follow,
because the rules the f**king stupid people made are f**king stupid f**king...
paradox?
so case scenario you cant source a second hand rubber intake, they dotn make them anymore and they all fall apart...Am I supposed to an expensive engineer certified exemption to put a modfied intake in? there has to be be some leniency there...the rules are f**king stupid, which is why nobody abides by them...on the other hand people are f**king stupid which is why there are laws....
its a balancing act :rofl:
You should have gone for a drive in the Stagea today, in that heavy rain. Still hooks up nicely. ;) You can't beat awd grip anytime.
I agree, intake pipes are exempt as long as the AFM is in the stock position and the BOV/Breather pipes are plumbed back. I wouldn't be asking a police officer how to interpret these laws though.
I have seen 500kw through stock GTR pipes, cooler and airbox, and also 430kw through a gtst with a return flow cooler. I have no idea where the idea these parts don't support more power started, but they were probably trying to sell their overpriced products.
Yes, the rubber gtst intake will definitely suck shut at around 250kw but it's a simple mod to replace the intake, and painted black it is barely noticeable. I still don't know if a replacement intake is legal though, as they only seem to mention pod filters.
Yes GTR's were over-engineered so that they could do that pretty comfortably. GOOD return flow coolers are very rare on a GTST budget, lettuce be real here lots (not all) owners of GTSTs just do basic mods like FMIC, pod and exhaust, maybe a bigger turbo if they're lucky. Not many people do the research and buy a good return flow from the beginning. The return pipe is simply too sharp of a bend, just like how on GTR's the rear turbo intake becomes a restriction because of how sharp of an angle the air has to change to get into the turbo. The idea has reasoning behind it, plenty of cars that can't crack much over the 300kw mark with a return flow when they should be making more, but at the same time, plenty that do make more power with a return flow, but they definitely can be a restriction.
The problem with the metal intake pipe (this is a good part of why I sold my GTST), is that it still isn't legal, even if it was same dimensions and looked pretty much the same, it's still an intake modification. Then when you get EPA'd and you have a bigger turbo inlet that won't accept the standard intake pipe, what do you do then?
yeah shitty weather conditions also favour the R
You don't have to tell me, I love the nm35 man, I drove Jethros in rain and fog...it is just amazingly easy to drive everywhere and the chassis/engine layout is incredibly well balanced..i prefered it to the GTR actually
Instead i drove the Cressida to Geelong on puring rain today..the chassis is balanced like a pendulam ...it also hooks up very well everywhere..with the LSD and fat kumhos I cant even get it to spin tyres in the wet now...and believe me i tried hard.... :P
where did you go??
Lol, you think the stock intake would save you from epa headaches when running a 4 inch aftermarket Garrett?
where did you go??
Autobarn was as far as my passenger wanted to let me drive. :P
This is Victoria, therefore everything's illegal when cop say it so.
Up to you to prove them otherwise.
This
You're not just avoiding the EPA, but having to prove yourself right in the first place which is the real pain in the ass. Testing paid for by yours truly in either case.
I'm also deterred by the cost of hiring a full time security guard
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
