It's not that tricky to do is it? Just drain and fill?
Unfortunately automatic transmissions are a bit more complicated to do. To drain all the fluid out you'll need a machine to pump it out, if you do it yourself you'll never 100% drain it properly.
I've tried it before on my FTO and by using a few different methods the maximum I could get was 4.5L / 7.5L, it's a piece of mind knowing that you can get it 100% changed over.
Sometimes I miss my old VL. Steering racks leaking, buckling wheels/panhard rods from drifting into gutters on rainy winter days. Filling the boot with bricks to give more lows. Freeze plugs rupturing coolant into my driveway.
I need to buy another 80's shit heap to keep me occupied. What I would do for an old Honda City turbo.
500 dorra buys my shit-house 31.
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
