Unfortunately automatic transmissions are a bit more complicated to do. To drain all the fluid out you'll need a machine to pump it out, if you do it yourself you'll never 100% drain it properly.
I've tried it before on my FTO and by using a few different methods the maximum I could get was 4.5L / 7.5L, it's a piece of mind knowing that you can get it 100% changed over.
DTM autos in geelong know how to do this (from experience)
Long way, but hey I lived in Hawthorn and went there..
I don't think there's a way to do it 'easily' though, it essentially needs to be running to flush the fluid out, and continually have new fluid put into it until everything inside it is new fluid. So if it holds 7.5L of fluid, you'll be using 10+ for a full flush as you can obviously never run the auto with zero fluid in it ;)
Thanks for that. Geelong is a bit too far for a simple automatic transmission flush haha. Yeah I figured I'd need 3 bottles (12L) for the full flush, will have to see what else is local :)
greg always does things the hard way.
the jatco auto box is actually in patrols and shit as well, any auto shop should be able to service it, its nothing special.
Lol when you get them you'll think they look really weak. Then you will question them.
Then you will question life and everything in existance and you will start growing your beard and hair because you will assume the hair dresser and clippers are out to kill you
Soon you will stop paying your mortgage and rent..
And you will be on the street warning everyone that judgement day is coming and then you will look back at what birds told you and think "I should've just driven the f**king thing"
yep. Anyone can service it. All you 'need' to do is add it at the rate you're losing it, easier said than done lol.
Also, anyone want to buy a forged RB28Neo?
Now with actual seriousness.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
