If I was single with no kid I would work FIFO for sure!
I am used to incredibly long hours and hard work from a decade of cheffing... I was all set to go then I met the Mrs and well.... Banker
My perception of you these days
Bank error in your favour collect $200
School tax pay $150
Nah I disagree, It's just our media hating on mining FIFO
Farmers in au 150K+
FIFO expected to hit 63K 2015.
who get more attention and hate?
add to that look at the source
a new limited paper, ie hearld sun equiv in WA.
basically they hate the fact some-one earns more than then so tried to make the rest of the population feel better about themselves.
not spotting the same articles about, IT consultants, those that do contracts in places like UAE/kuwait, and for that matter pilots.
all who probably spend longer from home
anyhow I'm stopping now as just over this topic.
Thanks for the shares.
I recommend reading the book 'boom' by Malcolm Knox.
Australia has a culture where we cut down tall poppies. If someone has less/same skillset & capacity as yourself but doing better off we tend to undermine them.
Back in the 1800's when prospecting was fuelling Australia's population boom, land titles with mineral deposits came to the people who found them first. There was no skill as gold & other resources were sitting on the surface ready for picking up.
The people who missed out caused hate to the successful & hence why out history books celebrate the thieves who robbed the miners/prospectors & not the finders themselves.
Fast forward to today and a mining fifo role is a perfect example where people can compare against themselves. An IT role requires specific skills not common to everyone & hence why I feel they wouldn't cop the same hate.
  • Like 1
we don't
even though I could train a relatively smart monkey to do my job.
Do they get paid as well as you lot
and that there is the essence of the problem..
"you lot."
as yes every-one there is exactly the same.
do you think the site foreman is on the same as a engineer is on the same as an explosives expert is on the same as a dump truck driver.
would I expect a PT to earn more FIFO than one in Melb, yes for sure.
would they slot into the pay grades in an appropriate spot yes. is it going to be as much as Pat with a uni degree and years of experience, hell no.
anyhow most PT not be abel to work there as they do Drug tests so they would be screwed..
  • Like 1
"you lot."
+1
Everyone gets paid their expected base salary which comes down to their qualification & experience.
My base is no different to working my position in melbourne.
The difference in fifo is if your roster means 30% extra hours you get paid extra 30%
However like all other jobs, if I work beyond my contract hours I don't get paid any over time. (13/14hr days against my 12hr roster)
You do get an extra couple of thousand dollars for living away from home compensation but it's small change
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
